I'm trying to measure the moisture content of wood via a resistance measurement. The moisture content range I'm trying to measure is in the order of 1 MΩ to 1 GΩ, so only ~5 nA current at 5 V DC.
The op-amp I'm using to amplify the current is an MCP6006R. I'm feeding this into the ADC on an Arduino. The datasheet shows a guard ring configuration around the inputs on the op-amp to minimize unwanted signals. Will this be necessary for the circuit to be reliable?
