I recently came across a USB charger (Xiaomi MDY-11-EZ) with the following specs:
5.0V=3A 15.0W
9.0V=3A 27.0W
12.0V=2.25A 27.0W
20.0V =1.35A Max 27.0W
11.0V=3.0A Max 33.0W Max
What confuses me about this is the fact that the charger has only a USB-A socket and comes with a USB-A -> USB-C adapter cable. Since the USB-A connector does not provide the necessary signals to negotiate any power delivery settings; how does the charger decide the output voltage?
As a side note: I also used this charger to power (/charge) a custom Li-ion-powered board which led to the destruction of the device after plugging in the USB cable. On the device I used the 5.1k resistors on the CC lines to get 5V with a PD-capable charger, which worked with no problems with other USB-C chargers...
Any ideas?
Best, Josh
