I am experimenting with digital counters and for one application it would be useful to generate a set of four pairs of 3-bit values used for comparing (Cx) and resetting (Rx) a counter. Since there are four possible outputs I think that it's possible to use two SPDT switches (Sx) that can be connected to GND and VCC to create these values.
Proposed truth table:
Calculating Cx and Rx values can be easily done with standard logic gates as follows:
C2= (¬S1) and (¬S0) = S1 nor S0;
C1= S1 xor S0;
C0 = S0;
R2 = 0;
R1 = ¬S1;
R0 = ¬S0;
In terms of used components (4000-series ICs) this would require a Hex Inverter (CD4049), a XOR Gate (CD4070) and either a NOR gate (CD4001) or an AND Gate (CD4081). Total of 3 ICs.
I was wondering if there is a more elegant solution for such a simple task. Perhaps problematic C2 and C1 value can be generated using discrete components. I would appreciate any improvement suggestions.
    \$\begingroup\$ Logic gates sound elegant but, if you think discreet components are elegant then that's up to you. Some people may think using an MCU is elegant. Others might think using tubes are more elegant. In other words, it boils down to what a person thinks is "elegant". \$\endgroup\$
    Jan 13, 2023 at 13:28
    \$\begingroup\$ You can invert something by XORing it with 1 or NORing it with 0 or itself. \$\endgroup\$
    – user253751
    Jan 13, 2023 at 14:11
use instead multipole switches:
Or use and gates and iverters.
or use all nand gates.
Come to think of it, it seems that this can be accomplished using only one XOR gate IC and couple of passives:
C2= (¬S1) and (¬S0) = S1 nor S0 = (S1 or S0) xor 1; \ XOR used as an inverter
C1= S1 xor S0;
C0 = S0;
R2 = 0;
R1 = ¬S1 = S1 xor 1; \ XOR used as an inverter
R0 = ¬S0 = S0 xor 1; \ XOR used as an inverter
OR gate needed for C2 can be accomplished with two diodes and pull down resistor.
So my proposed schematic is as follows: enter image description here
