First, I never used Zener and BJT before, so if I made something stupid please explain, I'm eager to learn.
The project is battery-operated and has 8 to 16 outputs with an individually selectable voltage for each one ; the choice is either to directly feed the output from the battery (9S-12S so about a 27V to 50V range) or from the main 12V buck. These outputs will mainly be used as ON/OFF switches or at low freq (< 100Hz), driving up to 2A and consuming as less quiescent current as possible.
I tried to find an off-the-shelf high-side driver but due to the "high" voltage, chip shortage and support for 100% ON time (so no bootstrapping), the only few I found were really expensive (and I need up to 16).
So, after spending some time tinkering, I came up with this circuit. I tried to make it simple, but with 2 twists:
- a BJT (Q1) to quickly turn off the pmos instead of a resistor
- a "pulsed" current to quickly turn on the pmos, without violating the Vgs limit at any moment, before settling to a low quiescent current (~50uA)
The principle is quite simple, but will explained in 2 steps. The PMOS is a BUK6D120, but the NPNs are not yet selected (I will naively consider beta=100 for the discussion). First, considering only R4, Q2 and R1, this a low power static circuit:
- Q2 and R4 are used as a rough current sink that draws about 50uA ;
- R1 will have about 9-10V when traversed by 50uA, enough to have the PMOS fully on. However, this is not enough to correctly/quickly drive the PMOS.
Now, considering the whole circuit, when switching the input from low to high, C1 is seen as a short circuit and the current will be limited only by R4//R3~=R3 ; this will temporarily increase the current sunk by Q2.
C1 is selected so that the "pulsed" current last long enough for the PMOS to change state while not dissipating too much power in Q2. However this higher current will increase the voltage across R1 and must be clamped to a safe value by the D1 zener.
Once C1 is charged, the circuit goes back to a 50uA quiescent current.
Here the value are chosen to have a symmetrical 5mA source/sink to the MOS gate, which should allow it to fully switch in about 2us.
Finally, when off, only leakage current is consumed, and D3 allows C1 to discharge.
Basic simulations seem to show that it is working as intended, but I'm out of my comfort zone. Did I overlook something? Any tips or improvement ideas?
Some notes:
- the circuit could be improved further by adding a push-pull stage before R2, but I feel it is not necessary in my case (should allow a few 100s mA and switching in a few 10s of ns). C1 could be lowered by an order of magnitude in that case.
- D3's anode could be attached directly to C1 for instant discharge, but feels unnecessary.
