I have a new AT90USB162 (docs). I would like to use my USB 2.0 socket and USB cable as a power supply for the microcontroller. I have two questions:
  1. How to adjust the current flow? In the documentation I have found that typical Icc should be about 13.5 mA (p. 263). It will be enough If I put a specific resistor between VBUS and UVCC and AVCC? I do not want to burn the device, like last time.
  2. If I find a correct way to power up my device via USB, then will this microcontroller be visible in Linux or Windows system? Any driver will be necessary?
the device
  1. You don't adjust the current flow. Definitely not with a resistor. Let the MCU take whatever current it requires to operate, at the voltage it operates.
  2. No it won't show up unless you write a program for the MCU which tells the PC what kind of USB device it is. If it is a device which does not need a driver then it will work, otherwise it needs a driver. It depends what kind of device you want your MCU to be.
