I just read about 'decoupling capacitors' to stabilize the voltage. I have some small voltage drops on this schematic when I made it into a PCB.
Can capacitors would solve the problem?
If yes, where do I have to put them?
Here's the PCB view. Maybe there is something wrong with it:
I measured on the M1/M2/M3 outputs. When I press SW1, I've 5.2V. When I press SW1 & SW2 I'm at 5.0V. When I press SW1 & SW2 & SW3 I land at 4.8V. Measured on the same (M1) output with both probes on GND and VCC of the connector.
