I am trying to use a subcircuit to replace a normal resistor for an FMEA. The .sub file looks like this:
.subckt testResistor In Out
.step param testResistorIterrator 0 4 1
.param BaseResistance= table(testResistorIterrator,   0, 1T,    1,  1,  2, 1.5k,    3, 0.5k,    4,1k)
.param BlockResistance = table(testResistorIterrator, 0, 1T,    1, 1T,  2, 1T,      3, 1T,      4,1)
R§Base Out In {BaseResistance}
R§Block Out 0 {BlockResistance}
.ends testResistor
In theory it should step iterate through 0 to 4 and assign the two resistors a value based on the step, however when I try to integrate the subcircuit in this test circuit: enter image description here
It gives me these errors:
WARNING: Can't resolve .param baseresistance=table(testresistoriterrator, 0, 1t, 1, 1, 2, 1.5k, 3, 0.5k, 4,1k)
WARNING: Can't resolve .param blockresistance=table(testresistoriterrator, 0, 1t, 1, 1t, 2, 1t, 3, 1t, 4,1)
Questionable use of curly braces in "râ§base out in {baseresistance}"
    Error: yet unevaluated parameter in: "[baseresistance]"
Questionable use of curly braces in "râ§block out 0 {blockresistance}"
    Error: yet unevaluated parameter in: "[blockresistance]"
Fatal Error:  Unable to find definition of model "baseresistance"
Did I declare something wrong, or is my entire setup wrong?
You cannot run a .step command within a subcircuit. The way to solve this is to make testResistorIterrator a regular parameter and then pass the stepped value from your top-level schematic to your subcircuit. You also need to define a default value to testResistorIterrator within your subcircuit. In other words, something like this:
.param testResistorIterrator=0
.param BaseResistance = table(testResistorIterrator,   0, 1T,    1,  1,  2, 1.5k,    3, 0.5k,    4,1k)
.ends testResistor
Then you right-click your subcircuit symbol and define either of the Value2, SpiceLine, or SpiceLine2 fields (doesn't matter which) as testResistorIterrator={value}, as shown below.
