I have a ZBMINI (not -L) and use it to toggle my heating (2kW). In between I put a contactor because I trust it to be more safe. The problem is that sometimes it toggles a few times extra. Depending on the amount, the heating is on whilst the switch is off?
Is this caused by inductive kickback as described here? If so, how do I calculate the snubber size/value?
contactor type: A9c20732 - datasheet
heater type: convector 2kW
The heater does have an optional fan built in. Should I see if this has impact?
Is there a type of contactor that I can use that does not give inductive kickback?
  • \$\begingroup\$ Please provide a data sheet link to the contactor. \$\endgroup\$
    Jan 17, 2023 at 12:39
  • \$\begingroup\$ What is the 2kW heater? Please use the edit link to put this detail in the question. \$\endgroup\$
    – rdtsc
    Jan 17, 2023 at 13:11
  • \$\begingroup\$ And how are controlling the contactor? \$\endgroup\$
    – DKNguyen
    Jan 17, 2023 at 15:13
  • \$\begingroup\$ The ZBMINI controls the contactor via Home Assistant. \$\endgroup\$
    – geiregjo
    Jan 17, 2023 at 15:41
I bought an RC absorption circuit and put it parallel over my contactor coil. I believe the issue is resolved now. But time will tell.
