I need help in identifying this smd Ic, which is a 6 pin smd package (most probably 1-3 watts led driver).
I have searched the smd marking sites:
1)https://www.s-manuals.com/smd/j5
2)https://smd.yooneed.one/code4a35.html
but the package is sot23-6 but i cant find similar one.
Ic image in first circuit ( marked J5CVC )
Ic image in second circuit ( marked J5EDE )
In some circuits its marked J5CTB also.
Possibly the Silergy Corp SM8102A 18V DC-DC Step-Down Regulator.
It's in a SOT23-6 package with a pinout that seems to reasonably match the circuit you show (capacitor from BS to LX, resistor network on FB pin, GND to big plane). The marking is a 5 digit number with the first two being J5 and the latter three digits being a date code which would explain why it varies between boards.
SM8102 Pinout and marking
  • \$\begingroup\$ Thanks for the reference. \$\endgroup\$
    – Chr_arj
    Feb 4, 2023 at 12:24
