I have been trying to decide the best single-supply non-inverting op-amp topology to use the ADC of an ATmega uC for capturing the signal coming from SCT013-030-0-30A-0-1V split-core current transformers.
The rated output of the sensor is 1 V, so the signal to be captured is a 50 Hz sine with a max. peak-to-peak amplitude of \$\small2\times\sqrt{2}=2.8284~\mathrm{V}\$.
Assuming that the A/D needs inputs in the 0-5 V range, I want to offset the signal by +2.5 V, in order to get a 50 Hz sine with a peak-to-peak range of 1.0858 to 3.9142 V. Furthermore, I'd like to amplify the signal by \$\frac{2.35~\mathrm{V}}{\sqrt{2}~\mathrm{V}}=\small1.6617\$, to better use the range of the A/D (0.15 V to 4.85 V).
I used the generalisation of a summing amplifier as a reference, and I focused on gain 1 at first.
In my use case, there are two positive inputs only,
- \$v_{p1} = v_i\$
- \$v_{p2} = v_{cc} = 5~\mathrm{V}\$
I can achieve \$v_o = v_i + \frac{V_{cc}}{2}\$ with or without \$R_{cp}\$:
Option FA:
Option FB:
I am unsure about which one is better. On the one hand, the gain in FA is 1.5 and the gain in FB is 2. Hence, I'd intuitively take the smaller gain, since noise is amplified along with the signal. However, in FA, the current flowing through \$R_{p2}\$ needs to flow through \$R_{p1}\$, and through the sensor. I wonder if that can somehow change the behaviour. Conversely, in FB, the current flowing through \$R_{p2}\$ can flow through \$R_{cp}\$.
As an alternative to adding the signals through the op-amp, I also considered using a divider as the reference of the sensor, instead of having it connected to ground:
Option FC:
Such a setup allows using the divider for multiple op-amps (each buffering one sensor). Yet, I wonder if this topology has some drawback, such making it less straightforward to match the impedances.
Transitient simulation of FA, FB and FC achieves the same result.
Then, I considered the case with gain 1. Option GA is the same as FA, with adjusted resistor values to achieve \$v_o = 1.667 \times v_i + 0.5 \times v_{cc}\$:
The same question as with FA and FB arises: is it desirable to add a resistor from V+ to ground and adjust the impedances?
Option GB:
Moreover, when adding the offset through a divider, \$R_{cn}\$ can be connected either to ground or to the reference of the sensor:
Option GC1:
Option GC2:
In option GC1, the bias is amplified by the op-amp. Therefore, the divider needs to be adjusted proportionally. Conversely, in option GC2 the op-amp is amplifying the signal only.
Transitient simulation of GA, GC1 and GC2 achieves very similar results.
Overall, I'd be grateful to receive any guidance that helps me pick GA, GB, GC1 or GC2.
As additional context:
- GA and GB allow to easily create a low-pass filter by adding a capacitor between V+ and ground. GC1 and GC2 would require adding a resistor between the sensor and V+ as well.
- The design is expected to include 5 sensors. Hence, reusing the reference divider (GC1 or GC2) might reduce the number of components on the board.
- It might be sensible to buffer the divider, in order to decouple the reference from the amplifiers.
