The problem is just making sure you can read and understand what's written. So the author gave you information in odd ways.
First off, you know that the voltage across the capacitor must be \$15\:\text{V}\$ at the moment the switch is opened. This follows because you know there is \$5\:\text{V}\$ across the \$R_1=3\:\Omega\$ resistor and you know that \$R_2=9\:\Omega\$ therefore, being three times larger, must have \$15\:\text{V}\$ across it and this must be what the capacitor was charged up to.
From this, and the given energy stored, you can work out the capacitance is \$30\:\text{mF}\$ and that the charge stored on it is \$450\:\text{mC}\$.
Now, at the end, you are told the voltage across the capacitor. So from this you can work out the final charge as \$1.625520348\:\text{V}\cdot 30\:\text{mF} = 48.7656104 \:\text{mC}\$.
Since you know that \$\frac{Q}{C}=i\cdot R\$ where \$i=\frac{\text{d}\,Q}{\text{d}t}\$ it follows that you need the solution to the differential equation, which is \$Q_t=Q_0\cdot\exp\left(-\frac{t}{R\,C}\right)\$. In short, all you need to do is find the value x in:
$$450\:\text{mC}\cdot\exp\left(-\frac{3\:\text{s}-2\:\text{s}}{\left(9\:\Omega+x\right)\cdot 30\:\text{mF}}\right)=48.7656104 \:\text{mC}$$
That solves out almost exactly to \$6\:\Omega\$. Which is surprisingly 'nice'.
