I am designing a wireless power transfer system based on the Royer oscillator ZVS principle. I based my circuit on the following image, this can be found in the application note [ANP032] page 21. enter image description here
The circuit I have designed is given below. enter image description here
The difference in this design is the following components: D701, D703 and D702 are 1N4148WS diodes with a If of 150 mA; Diodes D705, D704 and D700 are TVS bidirectional diodes 824521601.
The diodes given in the Example are: D701-> 1N5819HW: Io=1 A; D702 & D703-> Rb168M150: Io=1 A; D704 & D705-> Unidirectional TVS diodes 824550781; D700-> Bidirectional TVS diodes 824541151
I noticed that with whatever combination of coils, or capacitors I use for the Resonant frequency, I am only able to read about 0.1 A at the receiver end, with varying voltage levels (depending on the input, coil used for the receiver coil). I have a 200 Ω load on the receiver end. Also with increased current i.e., 2 A on the Tx side, the diode D705 always burns out. My observation was that I may need to change the diodes mainly D701, D705 and D706, but I am just shooting in the dark. Would this be the right assumption or is their something else wrong with the circuit?
The receiver circuit. J600 and J601 are both two pin connectors. enter image description here
Edit 1: enter image description here
  • \$\begingroup\$ Why did you use MOSFETs instead of diodes in your receiver? Did you tune the receiver to peak performance? \$\endgroup\$
    Jan 20, 2023 at 14:55
  • \$\begingroup\$ I made two receiver circuits, one with diodes for the full bridge rectifier, and the one with the MOSFETs was the second one i found, thought to make it for testing purposes. The circuit with the diodes burnt through, and this was the one that lasted with varying voltages. \$\endgroup\$ Jan 20, 2023 at 15:04
  • \$\begingroup\$ Did you monitor the output DC voltage when the diodes burned? This usually happens because you haven't implemented a voltage regulator for your load. What TVS diode did you use? Did you notice that your LED is the wrong way round? \$\endgroup\$
    Jan 20, 2023 at 15:17
  • \$\begingroup\$ I do not have a voltage regulator on the receiver side, this is because I am not aware of the voltage/current to expect. I gave an input of 24V,(Not sure of the exact current input <1.2A) ; measured a voltage somewhere close to 70V. \$\endgroup\$ Jan 20, 2023 at 15:25
  • \$\begingroup\$ I have slightly detuned the receiver circuit resonance frequency by 15-20% when compared to the Transmitter circuit. \$\endgroup\$ Jan 20, 2023 at 15:27
is there something else wrong with the circuit?
The receiver TVS diode is rated at 60 volts yet the electrolytic capacitors are only 50 volt type. The receive LED is incorrectly connected but this is trivial.
Then it's likely that this is the reason why your diodes burned; the TVS would heavily conduct and the diodes will "meet their maker" so to speak.
You should be benefiting from the fact that you have got such a decent received voltage and use a synchronous buck regulator to drop the voltage towards your target stabilized DC output (possibly 5 volts?). Use receiver tuning capacitors that are more than 100 volt rated and, pick a smoothing capacitor (after the bridge) that is also rated more than 100 volts.
I think your tuning capacitors are 250 volt rated so that's plenty good enough. However, do they have a decent dielectric like C0G. You can benefit from C0G capacitors a lot of the time.
That is a lot of detuning. With better tuning, you will benefit from a type of regulation (when the coils get close) because of the natural detuning effect as was shown in this answer. When significantly detuned, the effect isn't as good and, the distance-to-raw-output-voltage regulation can be horrible.
    \$\begingroup\$ Yes, the tuning caps are C0G, whereas the smoothening caps are X7R. I will test out with a more closer resonance frequency of the Rx with the Tx. Hopefully I can get a better Pout/efficiency. \$\endgroup\$ Jan 24, 2023 at 8:25
  • \$\begingroup\$ I am aiming for 20V,0.2A at the Rx end. \$\endgroup\$ Jan 24, 2023 at 8:32
