Stack Exchange network consists of 183 Q&A communities including Stack Overflow, the largest, most trusted online community for developers to learn, share their knowledge, and build their careers.
How do I subtract two S parameter curves and display the result? How do I do this for results from two different models in Advance Design System (ADS) software?
\$\begingroup\$Yes, there are two different files and I want to see the changes between their reflection (s33-s11) and transmission lines (s43-s21).\$\endgroup\$
\$\begingroup\$It's been a while but, just look for the command/object to load a 2nd dataset. Then write an equation that subtracts s11 from one file from s11 from the other file. Somethingl like delta_s11 = dataset1.S[1,1] - dataset2.S[1,1].\$\endgroup\$
. \$\endgroup\$
