I have a little problem. For a project I have to step up a 3V button battery to 12V to supply a DC motor (specifications of the problem). The hint that the professor gave to us is to make a double dc boost converter !
But the thing that is the motor is modelized by a 110 ohms resistor and my double boost converter can't reach the 12V at the output. He also told us to add at least one more transistor for the switching part of each boost converter. I also have some difficulty to design the components of my circuit.
Also one thing that i noticed is that the output voltage does depend on the switching frequency (my oscillator is a multivibrator astable and can work around 20kHz to 75kHz).
The specifications of the project :
- CR2032 battery or 3V supply;
- MOSFET transistors, reference ZVNL120A ;
- Geared motor ref. 20G150.
- coin battery type CR2032.
@Andyaka Okay i tried with a new method with 1 boost but 5 transistors in //. How can you explain this then ? The supply can be this button pile or another 3V supply like it said in the specs.
