Is there a formula for calculating the maximum current a wire can conduct without melting? I found one:
I = αd^(3/2) in which I = fusing current, d = wire diameter in inches, and α = a constant depending upon the material, which for copper is 10244.
But if I transform this formula to calculate the minimum diameter for a 1 A current I get a diameter of around 0.5 cm, which seems pretty large to me.
