Here is the section from a book I came across online:
If I don't get it wrong, it says the diodes D1 and D2 prevent currents to flow into the opamp in case of over voltage. And the reason they are Schottky type is because this type of diodes have low voltage drop which is preventing internal opamp diodes to conduct.
It then says the didoes also "have degrees of freedom". I guess it means the diodes have possibility that they must not act they supposed to be in some occasions. And therefore a series resistor Rlimit limits the current in such occasions.
Here is my confusion:
First of all I used to think that Rlimit is there to protect the diodes not the opmap input. But the text says the Rlimit is there to limit the input current of the opamp in case the external diodes fail.
But why would one needs external diodes if Rlimit already is capable of limiting the opamp input currents? Wouldn't the existence of Rlimit make D1 and D2 redundant already?
