I have a 12 VDC motor for a water pump which is for a water dispenser of the bottom-loading type. Basically it's a diaphragm type pump.
When I connect it, it rotates once, then stops. When I remove the load, it is still the same: one rotation, then it stops.
Electric supply is for motor Set for not continues but there is a pulse.
It should rotate intermittently to operate the pump.
Looks like the power supply activates overcurent protection. Some PSs shut off output when overloading. Brushed motor has start current bigger a few times of working current. You may use PS with restricted output current but it should provide enough power for start.
