I’m working on a project where I want to run a 3-phase induction motor (see picture for specifics) using a VFD (Variable Frequency Drive). The VFD I have is a cheap Chinese one (the “T13-750w-12-H”), but I’ve seen others have success with it.
However, when starting the VFD, the motor does spin, but with a slight hum and vibration, and it gets super hot after a few minutes running it at only around 10 Hz. Now I know that these are symptoms of a lost phase, but I’ve tried actually disconnecting a whole phase and that is MUCH more aggressive. I’ve also checked the voltage across each phase as its running and it looks fine in terms of evenness of voltage (at least to my untrained eye). Running the motor slowly (as low as a single Hz) you can even see how the rotor almost stops rotating for a split second every 6th of a turn or so.
The VFD is configured correctly, I’ve tried every setting I can find that’s relevant.
I’m starting to think it might be the VFD that is faulty.
Does anyone have any ideas?
