I am completely new to the SystemVerilog world, and I am trying to verify the asynchronous FIFO made by Cummings.
The goal is to verify this design by using the Tb components, so no UVM at all. I should basically focus on Generator (or sequencer), Driver, Interface, Monitor and Scoreboard.
There are at least 5 situations that I would like to verify which are: read only, write only, read/write at the same time, write when the FIFO is full, and read when the FIFO is empty.
Is it better to use two agents by splitting the write side and read side? If so, how can I realise the communication between the two of them when they need to provide the inputs and outputs to the monitor? Or is it better to use only one agent?
My original idea was to use a transaction with some constraints where I could use a 2-bit mode which is randomized and according to its value, I would have provided a specific stimulus (if mode =2'b00, then {winc, rinc} =2'b00 etc.) so that the Generator could just randomize all the inputs and eventually I should have at least 3 cases covered (write only, read only and write/read at the same time).
For the Write Full and Read Empty: I know the depth of the FIFO, and I would just declare a task that repeats itself one more time after the entire FIFO is filled and etc.
The point of this question is: is there any better way to proceed? Am I going in the wrong way? Maybe it's because I am unexperienced, but by randomizing everything and telling the generator to generate, don't know, 100 transactions, eventually every case will be covered I guess. Is a solution like this wrong?
