I am programming my STM32F030FPx TSSOP20 over SWD. I am simply trying to blink an LED by using the HAL GPIO library and the system timer to setup a delay. When I begin debug and let the program run, it crashes every time.
At first, I thought it was crashing due to a call to HAL_Delay, so I removed that and opted for a counter. I simply want a delay before and after toggling the LED pin.
My main loop only contains
while (1)
  HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
  while (i < 100)
    i = i + 1;
  i = 0;
I started with a number way larger than 100 but tuned it down just to make sure it got through when I used the debugger to step through. I don't think it can get much simpler than this. I am able to step through the loop 100 times and get the LED to toggle back off after I turn it on through the first pass through the while loop. However, when I do not step through manually with the debugger, the program crashes and this is what the IDE presents.
I am not sure how to interpret what is going on. Is there a problem with the dependencies I might be using? What is <signal_handler_called>() meant to indicate? Which signal is being handled?
    \$\begingroup\$ Did you use MX to set up the clocks and initialize GPIO (including related clocks)? \$\endgroup\$ Jan 24, 2023 at 2:38
  • \$\begingroup\$ Looks like a HardFault (or a BusFault which got elevated into one), the most likely cause being what Spehro mentioned above - you probably haven't configured your system clocks, and as a result trying to access the GPIOA module produces a fault. \$\endgroup\$
    – brhans
    Jan 24, 2023 at 3:27
  • \$\begingroup\$ Yes, I used MX inside of STM32CubeIDE \$\endgroup\$
    – Jack Frye
    Jan 25, 2023 at 1:07
