I need to use this Cree LED in a PCB design, but I have a question about it: what is the connection of the pads?
This component has a footprint with 4 pads:
footprint_image.
This footprint is provided by the KiCad library, and matches with my LED producer's dimensions and number of pads.
When I make a schematic with it and I choose the typical diode symbol with 2 pins, and switch to designing the PCB it suggest connections for pin 1 and 2 (both left pins), but what happened with the other 2?
I don't know if pins 1 and 2 must be connected as well, or not, and I didn't find anything in the datasheet.
Can anyone who has worked with it help me?
This is the 2-pad arrangement recommended in the Cree data sheet for your device: -
