I'm trying to compile a project where I have add the Software Pack RTOS ThreadX
on a STM32F4 and I'm using uVision Keil 5.29.
I have included ThreadX in the project by CubeMX (option Select Components
of the Menù Software Packs
When I compile the project created by CubeMX (I have not modified anything) the linker give the following 3 errors:
Error: L6218E: Undefined symbol __RAM_segment_used_end__ (referred from tx_initialization_low_level.o).
Error: L6218E: Undefined symbol _vectors (referred from tx_initialization_low_level.o).
Error: L6218E: Undefined symbol g_pfnVectors (referred from tx_initialization_low_level.o).
This means that the 3 symbols are not defined. All the symbols are used in the object file tx_initialization_low_level.o
Note. The assemmbler module tx_initialization_low_level.s
has been inserted in the project by RTOS ThreadX
How can I define the 3 symbols (__RAM_segment_used_end__
, _vectors
, g_pfnVectors
) to solve these errors?
Thanks
