This is the Apple-proprietary "Chestnut" IC (and there are no datasheets to be found). From the part number, it's probably made by Texas Instruments for Apple.
I think the other commenters are correct and it's a flying capacitor for a charge pump to generate the negative rail. The positive boost rail is generated by a boost inductor (the 1.5uH inductor cropped off the left edge and connected to the SW pin). Since it's connected directly from the main Vcc to the chip, it can only be a boost converter.
Since there's only one inductor connected to the chip, that leaves a capacitor charge pump as pretty much the only possibility to generate a negative rail from the main Vcc (in this case, I think it's generated indirectly by an inverting charge pump fed back into the chip from the positive boost rail).
Then there are a few positive output LDOs, I2C communication and some other control and monitoring lines.
