I just bought a NEMA 17 motor and some DRV2285 drivers and am following this tutorial.
Originally, the problem was that the stepper motors weren't turning, only vibrating. I was able to adjust the voltage using a multimeter. Now, all my voltage values are reading zero from the motor driver. I verified that my multimeter wasn't the culprit by checking my 12 V, 2 A power supply that I'm using to power my driver. Now, the stepper motor won't turn too. How do I get my stepper motor working? Any help would be appreciated.
Here is the code I am using:
// Include the AccelStepper Library
#include <AccelStepper.h>
// Define pin connections
const int dirPin = 5;
const int stepPin = 4;
// Define motor interface type
#define motorInterfaceType 1
// Creates an instance
AccelStepper myStepper(motorInterfaceType, stepPin, dirPin);
void setup() {
    // set the maximum speed, acceleration factor,
    // initial speed and the target position
    myStepper.setMaxSpeed(1000);
    myStepper.setAcceleration(50);
    myStepper.setSpeed(200);
    myStepper.moveTo(200);
void loop() {
    // Change direction once the motor reaches target position
    if (myStepper.distanceToGo() == 0)
        myStepper.moveTo(-myStepper.currentPosition());
    // Move the motor one step
    myStepper.run();
I am using the wiring shown in the article I linked above, except my DIR pin is in pin 5, and my STEP pin is in pin 4 because pins two and three are being used:
wiring diagram
    \$\begingroup\$ Why have you defined the pins as 4 and 5 but connected 2 and 3? \$\endgroup\$ Jan 25, 2023 at 23:36
  • \$\begingroup\$ Red green yellow blue is unusual for a stepper. All of mine are red blue green black. Maybe your wires are mixed up? Can you use a multimeter to check the DC resistance of each pair of wires? If your wiring's right, measuring red and green should be less than 10 ohms. \$\endgroup\$
    – Matt S
    Jan 25, 2023 at 23:45
  • \$\begingroup\$ My wires are red blue green black too. The diagram on the website just says red green yellow blue. I used a multimeter and switched the two middle wires(blue and green) after the motor stopped vibrating all together. Now I think I have the correct wiring, but the motor will not turn in any wiring configuration. Did I blow my motor? I tested all five of my drivers and none of them make the motor vibrate anymore. \$\endgroup\$
    – 3DCoded
    Jan 26, 2023 at 11:37
This morning, I changed the driver and it worked!
    \$\begingroup\$ Did you change anything else from your original setup? Your previous comment implied that you already tried changing drivers. \$\endgroup\$
    – Matt S
    Jan 26, 2023 at 22:04
  • \$\begingroup\$ "I tested all five of my drivers and none of them make the motor vibrate anymore." Are you saying that all of those 5 drivers were damaged, and the existing setup with a new driver worked? If so, can you explain what could have damaged those drivers? \$\endgroup\$
    – Velvet
    Jan 27, 2023 at 7:06
  • \$\begingroup\$ I did try using 24V at 4A on some of them, which may have damaged them. I also accidentally shorted out some of the pins when trying to adjust the potentiometer with a screwdriver. These were also cheap drivers, so that could have played a part. One of them had a hole in the chip and started smoking... \$\endgroup\$
    – 3DCoded
    Feb 10, 2023 at 12:40
