An application requires a -5 V negative power supply with max 550 mA. I can't find a reliable dedicated positive to negative converter for such currents in the market at a reasonable price.
I came up with this DC-DC converter and here is the datasheet.
Can I just ignore the +Vout and only use -Vout for a circuit which requires -5 V and max. 550 mA where ambient temperature will not exceed 40°C? And if I use an op-amp with such a negative supply should it be dual type?
