How do I measure voltage between two nodes when neither of them is ground? In the schematic below, I want to measure the voltage between nodes Vmic and Vx. Is it just (Vmic-Vx)? I'm afraid that gives a wrong answer.
You can use .meas Vmicpk MAX(V(Vmic)-V(Vx))*1000
Vmic
and Vx
are node names and not voltages.
The voltages associated with each node are V(Vmic)
and V(Vx)
The difference voltage between the two nodes is V(Vmic)-V(Vx)
Then multiply by 1000 if that's what you want.
In addition to the other answers, in LTspice you can identify in any command the voltage across two nodes with the syntax
V(node1,node2)
which in your case becomes
V(Vmic,Vx)
\$\begingroup\$ That will be useful for quick analysis. Thank you. \$\endgroup\$ Jan 29 at 13:25
Use a differential voltage probe.
Click on the first node, and drag to the second node.
\$\begingroup\$ Nice. This can be used when viewing simulation window. \$\endgroup\$ Jan 29 at 13:24
