I just made two LED panels each consisting of two colors of LED strips.
They are wired in a way that allows it to be powered from a 19V (3.42A) laptop power supply:
(This image shows only one panel.)
These are 60 SMD3528 per meter LED strips.
How can I drive the two colors (separately) at at least 10kHz from an Arduino MKR WiFi 1010 (3.3V)?
I already found that I should drive them with an IRF520 or IRF630 MOSFET, but apparently they will not be able to handle that high frequency. I need the high frequency because I am going to be using those panels for photography and filming.
What would you suggest?
