I need to drive inductive load (Helmholtz coil) with power requirement of V = 800V and I= 10A. Planning to use FET based half-bridge circuitry to achieve this. If anyone has better solution to this please post your feedback.
  • \$\begingroup\$ I think this is highly suitable for a SiC bridge. Parts with 1200 V and more rating are readily available. \$\endgroup\$
    – tobalt
    Jan 30 at 18:55
  • \$\begingroup\$ AC or DC? Carrier frequency (if AC) and bandwidth? \$\endgroup\$
    – TimWescott
    Jan 30 at 19:59
  • \$\begingroup\$ @TimWescott Its DC supply. \$\endgroup\$ Jan 30 at 20:46
  • \$\begingroup\$ What range of voltages do you want to apply? Up to 800, I assume. Do you want to go negative? How fast do you want to change voltage? \$\endgroup\$
    – TimWescott
    Jan 30 at 21:04
  • \$\begingroup\$ Please edit your question to fill in these blanks. \$\endgroup\$
    – TimWescott
    Jan 30 at 21:04
