I am testing this circuit on a PCB that I've built and I'm experiencing a 1 mA current draw when enabling it. The aim is to turn on/off a transceiver that needs 3 V and max current draw of around 500 mA. TCVR_PWR is controlled from an MCU with voltage domain being 3 V as well. I'm suspecting that I made an error in my component selection (NPN or the P-channel) but I'd like a second opinion because I can't identify any issues so far.
TCVR is currently in sleep mode due to AT Commands sent, and draws 4 nA when in said power mode. I can test the difference by shorting 3V0 and 3V0TCVR through a 0 Ω resistor (not pictured in the schematic), which is how I noted the 1 mA current difference.
