I tried to make single-wire half-duplex communication with a UART using the STM32F103C8 controller. In single-wire half-duplex communication, a TX pin is used for transmitting and receiving the data.
I had configured the pins and register with the help of a datasheet (reference manual for STM32F103C8). So I tried to transmit the data from one bluepill board (STM32F103C8) and to receive the data in another bluepill board (STM32F103C8). But I am not able to transmit and receive data. I have enclosed my code. Can anyone help me to solve it? I have used the register for the code.
Communication: USART3
Pins: PB10-TX
STM32 reference manual
Here is my code for UART3 single-wire half-duplex communication
#include<stm32f10x.h>
char receive;
void USART3_init(void)
    RCC->APB1ENR |= RCC_APB1ENR_USART3EN ;
    USART3->BRR = 0x0EA6;  //0x1D4C //0x0EA6
    USART3->CR3 |= USART_CR3_HDSEL;
    USART3->CR1 |= USART_CR1_RE ;
    USART3->CR1 |= USART_CR1_TE ;
    USART3->CR1 |= USART_CR1_TCIE;
    USART3->CR1 |= USART_CR1_UE;
int main()
    RCC->APB2ENR |= RCC_APB2ENR_IOPBEN | RCC_APB2ENR_AFIOEN;
    GPIOB->CRH = 0x00000F00;
    USART3_init();
    while(1)
       USART3->DR = data;
       while (!(USART3->SR & (1<<6)));
  • \$\begingroup\$ Your code has no transmitting and no receiving statements. Please edit your question and add it. -- A while loop inside an ISR is most of the time plain wrong. \$\endgroup\$ Feb 2, 2023 at 6:42
  • \$\begingroup\$ @thebusybee thanks for the response while loop is to Wait for TC to SET. This indicates that the data has been transmitted \$\endgroup\$ Feb 2, 2023 at 7:40
  • \$\begingroup\$ GPIOB->CRH = 0x00000F00; - port is set in open-drain mode. Do you have externall pull-up resistor? \$\endgroup\$
    – Flexz
    Feb 2, 2023 at 8:10
    \$\begingroup\$ Yeah, I know that you want to wait for the completion. However, this is not how interrupt-driven transmission is supposed to be used. Anyway, you change the code. -- How do you know that there is no transmission? Did you measure the line with an oscilloscope? -- There is still no receiving source. How do you know that there is no reception? -- You did not add a statement concerning the necessary pull-up resistor. \$\endgroup\$ Feb 2, 2023 at 9:38
    \$\begingroup\$ Please add such important information to your question by editing. -- To be clear: Your logic analyzer does not show any transmission. Is this correct? What level does it show? -- "Open drain" is not a synonym for "pull-up". Actually, an open-drain output has no pull-up according to the reference manual. You need to provide an extra pull-up. Please add a resistor and repeat, post the result in the question as advised above. \$\endgroup\$ Feb 2, 2023 at 13:27
I was having a similar issue getting a USART single-wire half-duplex to work on a STM32 microcontroller using ST's Cube MX IDE.
I believe their IDE has a bug in it's code-generation for half-duplex support. I'm running version v1.2.0 from early 2020, so perhaps its fixed in newer versions, but this is how I got it to work.
What I'm sharing is the difference between going from (a working) full-duplex two-wire UART/USART to a 1-wire half-duplex. In this particular case, I got it working in "tx-only" instead of rx/tx. I'll share that difference below.
So this is how I'm configuring the pin in the "Device Configuration Tool":
And here is the other configuration for the peripheral:
Next, these are the code changes that you'll need to make to stm32l4xx_hal_msp.c. I found that the STM32 Cube MX tool completely removed the calls to HAL_GPIO_Init() in its generated code which is wrong.
So again, these are the changes I needed to make between a working full-duplex and my new half-duplex configuration in stm32l4xx_hal_msp.c. I found all the other generated code to be correct:
    @@ -557,7 +492,6 @@ void HAL_UART_MspInit(UART_HandleTypeDef* huart)
     __HAL_RCC_GPIOA_CLK_ENABLE();
     /**USART2 GPIO Configuration
     PA2     ------> USART2_TX
-    PA15 (JTDI)     ------> USART2_RX
     GPIO_InitStruct.Pin = VCP_TX_Pin;
     GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
@@ -566,13 +500,6 @@ void HAL_UART_MspInit(UART_HandleTypeDef* huart)
     GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
     HAL_GPIO_Init(VCP_TX_GPIO_Port, &GPIO_InitStruct);
-    GPIO_InitStruct.Pin = VCP_RX_Pin;
-    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
-    GPIO_InitStruct.Pull = GPIO_NOPULL;
-    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
-    GPIO_InitStruct.Alternate = GPIO_AF3_USART2;
-    HAL_GPIO_Init(VCP_RX_GPIO_Port, &GPIO_InitStruct);
   /* USER CODE BEGIN USART2_MspInit 1 */
   /* USER CODE END USART2_MspInit 1 */
@@ -600,7 +527,7 @@ void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
-    HAL_GPIO_DeInit(GPIOA, VCP_TX_Pin|VCP_RX_Pin);
+    HAL_GPIO_DeInit(GPIOA, VCP_TX_Pin);^M
   /* USER CODE BEGIN USART2_MspDeInit 1 */
And here is a graphical screenshot from gitk in case you prefer its presentation:
