When I apply 4.8 V (Arduino 5 V) to the B side of my level shifter TXB0108, I always get 1.2 V (which is the minimum) on the A side.
Is it possible to get something like 3.3 V or at least 1.8 V (it's the minimal required for my device)?
Back side
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhen I apply 4.8 V (Arduino 5 V) to the B side of my level shifter TXB0108, I always get 1.2 V (which is the minimum) on the A side.
Back side
Feeding 5 V into VB, it is not possible to get 3.3 V from VA:
Both VA and VB are power supply inputs.
There is no supply output:
This is a bidirectional logic level shifter without direction control input.
Converting one level voltage to another is a job for a (voltage) converter,
5 V DC to 3 V DC would be DC/DC converter, efficiency of 0.85 should be well possible.
Voltage regulators have been used for this; a "linear" one would have an efficiency below 0.6 here.
The use of a logic level shifter is to connect logic level terminals of sub-circuits with incompatible logic levels.
The supplier of the TXB0108 once published a Voltage Level Translation Guide.
