With an STM32 microcontroller I use timer 2 channel 4 to generate PWM:
HAL_TIM_PWM_Start_IT(&htim2, TIM_CHANNEL_4);
And I use HAL_TIM_PWM_PulseFinishedCallback to send data through SPI at the end of each PWM falling edge. It means at the end of each PWM pulse(end of duty cycle), PWM_PulseFinishedCallback is called and I implement SPI transmit function in there.
But I noticed it takes several microseconds between the time the actual pulse is finished(falling edge) and the time when the PWM_PulseFinishedCallback is called.
As you see after the actual pulse is finished(falling edge of PWM) some extra time passes until the callback is called and SPI enable pin goes LOW.
So how can I modify the IRQ handler so that HAL_TIM_PWM_Start_IT can be called earlier?:
@verbatim
##### IRQ handler management #####
This section provides Timer IRQ handler function.
@endverbatim
* @brief This function handles TIM interrupts requests.
* @param htim TIM handle
* @retval None
void HAL_TIM_IRQHandler(TIM_HandleTypeDef *htim)
/* Capture compare 1 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC1) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC1) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC1);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_1;
/* Input capture event */
if ((htim->Instance->CCMR1 & TIM_CCMR1_CC1S) != 0x00U)
#if (USE_HAL_TIM_REGISTER_CALLBACKS == 1)
htim->IC_CaptureCallback(htim);
#else
HAL_TIM_IC_CaptureCallback(htim);
#endif /* USE_HAL_TIM_REGISTER_CALLBACKS */
/* Output compare event */
else
htim->OC_DelayElapsedCallback(htim);
htim->PWM_PulseFinishedCallback(htim);
#else
HAL_TIM_OC_DelayElapsedCallback(htim);
HAL_TIM_PWM_PulseFinishedCallback(htim);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_CLEARED;
/* Capture compare 2 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC2) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC2) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC2);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_2;
if ((htim->Instance->CCMR1 & TIM_CCMR1_CC2S) != 0x00U)
#else
else
#else
/* Capture compare 3 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC3) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC3) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC3);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_3;
if ((htim->Instance->CCMR2 & TIM_CCMR2_CC3S) != 0x00U)
#else
else
#else
/* Capture compare 4 event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_CC4) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_CC4) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_CC4);
htim->Channel = HAL_TIM_ACTIVE_CHANNEL_4;
if ((htim->Instance->CCMR2 & TIM_CCMR2_CC4S) != 0x00U)
#else
else
#else
/* TIM Update event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_UPDATE) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_UPDATE) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_UPDATE);
htim->PeriodElapsedCallback(htim);
#else
HAL_TIM_PeriodElapsedCallback(htim);
/* TIM Break input event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_BREAK) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_BREAK);
htim->BreakCallback(htim);
#else
HAL_TIMEx_BreakCallback(htim);
#if defined(TIM_BDTR_BK2E)
/* TIM Break2 input event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_BREAK2) != RESET)
__HAL_TIM_CLEAR_FLAG(htim, TIM_FLAG_BREAK2);
htim->Break2Callback(htim);
#else
HAL_TIMEx_Break2Callback(htim);
#endif /* TIM_BDTR_BK2E */
/* TIM Trigger detection event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_TRIGGER) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_TRIGGER) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_IT_TRIGGER);
htim->TriggerCallback(htim);
#else
HAL_TIM_TriggerCallback(htim);
/* TIM commutation event */
if (__HAL_TIM_GET_FLAG(htim, TIM_FLAG_COM) != RESET)
if (__HAL_TIM_GET_IT_SOURCE(htim, TIM_IT_COM) != RESET)
__HAL_TIM_CLEAR_IT(htim, TIM_FLAG_COM);
htim->CommutationCallback(htim);
#else
HAL_TIMEx_CommutCallback(htim);
/** @defgroup TIM_Exported_Functions_Group8 TIM Peripheral Control functions
* @brief TIM Peripheral Control functions
@verbatim
