-1
Assuming a simple binary state variable allocation can be made and that any unused states can be treated as don’t cares. How would I Design a corresponding transition table for this system including flip-flop (D- FF) inputs and system inputs/outputs. (I am unsure why the table looks so weird outside of the editor its my first time using this). Here is the State table:
State Clock A B C R1 Y1 G1 R2 Y2 G2 Output
S0 5s 0 0 0 1 0 0 1 0 0 S1
S1 6s 0 0 1 1 1 0 1 0 0 S2
S2 80s 0 1 0 0 0 1 1 0 0 S3
S3 6s 0 1 1 0 1 0 1 0 0 S4
S4 5s 1 0 0 1 0 0 1 0 0 S5
S5 6s 1 0 1 1 0 0 1 1 0 S6
S6 80s 1 1 0 1 0 0 0 0 1 S7
S7 6s 1 1 1 1 0 0 0 1 0 S0
I have tried this 3 times and got it wrong three times any help would be greatly appreciated.
My attempt:
State D0 D1 C0 C1 R1 Y1 G1 R2 Y2 G2
S0 0 0 0 0 1 0 0 1 0 0
S1 0 0 1 0 1 1 0 1 0 0
S2 0 1 0 0 0 0 1 1 0 0
S3 0 1 1 0 0 1 0 1 0 0
S4 1 0 0 0 1 0 0 1 0 0
S5 1 0 0 1 1 0 0 1 1 0
S6 1 0 1 0 1 0 0 0 0 1
S7 1 0 1 1 1 0 0 0 1 0
(D0 and D1) represent the binary state variable allocation. (C0 and C1) represent the system inputs/outputs.
  • \$\begingroup\$ How would i design a transition table from this state table? \$\endgroup\$ Feb 3, 2023 at 17:25
  • \$\begingroup\$ looks like a homework assignment \$\endgroup\$
    – Roland
    Feb 3, 2023 at 17:27
  • \$\begingroup\$ its a self project assignment since I'm studying electronics alone I have done the Karnaugh and VHDL myself I also built the logic system but I cant get the excitation or transition maps correct and I don't know where I am going wrong \$\endgroup\$ Feb 3, 2023 at 17:28
  • \$\begingroup\$ Edited with my try of the transition table \$\endgroup\$ Feb 3, 2023 at 17:36
    \$\begingroup\$ Seems that these are traffic lights ... \$\endgroup\$
    – Antonio51
    Feb 3, 2023 at 17:59
See this note for reference.
So, the problem is "synthetizing" a "counter" ... with D-FF, and you need 3 D-FF.
Your second table is not what you are "searching" ...
When "counter" will be synthesized ...,
you should be able to draw a circuit like this (this is only the beginning ... and a "fast" version.
Only the first "light" is drawn (R1). You should do the same for other lights.
NB: the timing is not included, only the "sequence". Should use also some timers.
The 74151 is used as a "general" function of 3 variables (can be "extended").
