I wrote VHDL to instantiate some RAM (256 bytes) using BRAM on a Digilent BASYS 3 FPGA development board using Vivado design tools. It takes 8 bits as the data input and outputs 8 bits on the output. A write to RAM is synchronous and performed on the rising edge when store (write) input is high. Read from output port is always performed by forced to zeros if the enable signal is high with AND gates.
My issue is that the RAM output is always zeros. Even if I define all 256 bytes as 0xFF (others => 0xFF) the output is still zeros. Can anyone see the problem here?
Code is as follows with a simulation and :
Code
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity Random_Access_Memory is
  Port (D_i            : in std_ulogic_vector(7 downto 0);
        Addr_i         : in std_ulogic_vector(7 downto 0);
        Clock_i        : in std_ulogic;
        Store_i        : in std_ulogic;                      --Active low input
        Enable_i       : in std_ulogic;                      --Active low input
        Q_o            : out std_ulogic_vector(7 downto 0);
        Addr_in_temp_o : out integer range 0 to 255
end Random_Access_Memory;
architecture Behavioral of Random_Access_Memory is
type RAM_ARRAY is array (0 to 255) of std_ulogic_vector(7 downto 0);
signal RAM  : RAM_ARRAY :=
--     0      => "00000001",
--     1      => "11111111",
--     2      => "00010000",
     others => "11111111"
signal Addr_in_temp  : integer range 0 to 255;
signal D_in_temp     : unsigned(7 downto 0);
signal D_out_temp    : std_ulogic_vector(7 downto 0);
begin
    Process(Clock_i, Addr_i)
    begin
    if(rising_edge(Clock_i)) then
        if(Store_i = '0') then
            RAM(Addr_in_temp) <= D_i;
        end if;
    end if;
    end Process;
Addr_in_temp_o <= Addr_in_temp;
Addr_in_temp <= to_integer(unsigned(Addr_i));
D_out_temp <= RAM(Addr_in_temp);
Q_o(0) <= D_out_temp(0) and (not Enable_i);
Q_o(1) <= D_out_temp(1) and (not Enable_i);
Q_o(2) <= D_out_temp(2) and (not Enable_i);
Q_o(3) <= D_out_temp(3) and (not Enable_i);
Q_o(4) <= D_out_temp(4) and (not Enable_i);
Q_o(5) <= D_out_temp(5) and (not Enable_i);
Q_o(6) <= D_out_temp(6) and (not Enable_i);
Q_o(7) <= D_out_temp(7) and (not Enable_i);
end Behavioral;
Testbench
library IEEE;
entity Top_tb is
end Top_tb;
architecture Behavioral of Top_tb is
component Random_Access_Memory is
end component;
signal D_i_tb      : std_ulogic_vector(7 downto 0);
signal Addr_i_tb   : std_ulogic_vector(7 downto 0);
signal Clock_i_tb  : std_ulogic;
signal Store_i_tb  : std_ulogic;
signal Enable_i_tb  : std_ulogic;
signal Q_o_tb      : std_ulogic_vector(7 downto 0);
signal Addr_in_temp_o_tb : integer range 0 to 255;
constant clock_period : time := 10 ns;
begin
DUT : Random_Access_Memory
    Port map (D_i      =>  D_i_tb,
              Addr_i   =>  Addr_i_tb,
              Clock_i  =>  Clock_i_tb,
              Store_i  =>  Store_i_tb,
              Enable_i =>  Enable_i_tb,
              Q_o      =>  Q_o_tb
Clock_Gen : Process
    begin
    Clock_i_tb <= '0';
    wait for clock_period/2;
    Clock_i_tb <= '1';
    end process;
D_i_tb      <= "00000000";
Addr_i_tb   <= "00000001";
Store_i_tb  <= '0';
Enable_i_tb <= '0';
end Behavioral;
Simulation Waveform
Simulation Waveform
    \$\begingroup\$ Shouldn't if(Store_i = '0') then check for a 1 instead of a 0? \$\endgroup\$
    – po.pe
    Feb 4, 2023 at 13:53
  • \$\begingroup\$ Actually I wrote the question wrong, the Store_i input should be active low so I should have had the testbench setting the Store_i input high instead of low and continually writing to RAM. Thanks for pointing that out. \$\endgroup\$
    – David777
    Feb 4, 2023 at 20:27
  • \$\begingroup\$ Why does RAM VHDL simulation output unexpectedly always shows zero? \$\endgroup\$ Feb 8, 2023 at 19:38
There are some small problems in your code: The output Addr_in_temp_o of Ramdom_Access_memory is not connected in your testbench. So the simulation always shows the value 0 (default value of integer) at the signal Addr_in_temp_o_tb. The clocked process in Random_Access_Memory is also sensitive to Addr_i which is not needed.
But the real problem is: In your testbench you permanently write (store=0) a 0 into the address 1 and you also read permanently (enable=0) from address 1. So of course you always read 0. If you zoom in at the time 0, you perhaps can see the value FF for 1 clock cycle at the read data output.
Assuming you are interested only in simulated behaviour, since this initialization may not be synthesizeable, both types work:
signal RAM : RAM_ARRAY := ( others => (others => '1') );
signal RAM : RAM_ARRAY := ( others => "11111111" );
But, since you are not stopping the simulation, you don't see the first and only cycle when the 0xFF appears. To stop it, you could do the following:
Clock_Gen : Process
begin
    Clock_i_tb <= '0';
    Clock_i_tb <= '1';
    wait; -- Stop the simulation
end process;
