Micro-Cap 12 won't let me put a conditional statement in its capacitance parameter to vary its capacitance per conditions. I'm using this capacitor as a throttle which I name: 'tcap' ...
.define tcap {100f + STOP}
.define STOP if(I(IndLoad) > 300, 30p, 0)
The intention is to raise the capacitance of tcap to 30pF (or, more) if the current of IndLoad should rise to a minimum of 300 amperes. The default capacitance of tcap is 100 femto Farads.
What do I do?
  • \$\begingroup\$ How do you expect to realize this in a real circuit? Perhaps your simulation should model that more literally. Two capacitors and a switch? \$\endgroup\$
    – Dave Tweed
    Feb 4 at 18:20
  • \$\begingroup\$ @DaveTweed Good idea. Thanks. I was thinking of a variable capacitor, but maybe that's not practical, nor doable, per these requirements? \$\endgroup\$
    – Chet
    Feb 4 at 18:28
