I try to identify this connector - it is used for power and 24V signals in a scientific device.
CONNECTOR
The dimensions of the plugged connectors are:
  • 40.7 mm (full length)
  • 6.6 mm (height)
  • 13.65 mm (width - 2 pins)
Pitch 6.x mm (~6.8)
Is there a structured process how for dealing with a question like this?
Thanks!
    \$\begingroup\$ Can you unplug it and show us what the mating ends look like? \$\endgroup\$ Feb 7, 2023 at 10:57
    \$\begingroup\$ Also let us know the pitch (the distance between the pins) as accurately as you can. \$\endgroup\$
    – Graham Nye
    Feb 7, 2023 at 11:46
  • \$\begingroup\$ And also, what device the connector is used in, make and model ideally (eg a 24v fan, but inside a computer power supply? a projector? a battery charge unit?) \$\endgroup\$
    – raaymaan
    Feb 7, 2023 at 11:54
Those are pin-and-socket connectors (my site).
Specifically, they look like they use 0.093" contacts and a 6.3 mm pitch. If so, they are made by multiple manufacturers, including:
Pin and socket connectors
{Digikey}
If the contacts have a different diameter, please measure the inner diameter of the sockets, edit your question, and specify the diameter.
If I may, please let me direct you to my Identiconn - Connector Identification Utility.
