I'm working on a cubesat project intended to operate in low earth orbit. We're considering a few different options for our flight computer, ranging from Raspberry Pi to something like STM32L476. Despite being told repeatedly that "Raspberry Pis have a decent heritage in space," I'm not fully convinced.
It's hard to get a good picture of just how hazardous the conditions in LEO are to electronics.
  • What range of radiation doses would we expect?
  • How spaceworthy are microprocessors and microcontrollers for non critical and somewhat cost sensitive space applications?
  • Would a watchdog timer be reasonably sufficient to protect against faults at lower radiation doses?
  • More specifically, assuming we design our software accordingly and use STM32's watchdog peripherals, how long should we expect to survive in LEO from strictly failure caused by radiation?
Here are some resources I found, but they don't answer my questions completely.
Some more information about my particular situation:
  • We are very sensitive to cost so we cannot use all space-rated components for no reason. Vorago's radiation hardened MCUs that are about $1k per piece are out of our consideration as well.
  • Thermal issues will be considered separately, but I have a reasonable idea of what to expect and how to perform testing. It's also quite easy to test compared to ionizing radiation.
  • 7
    \$\begingroup\$ > Despite being told repeatedly that "Raspberry Pis have a decent heritage in space," I'm not fully convinced. Thanks, me neither. It's a mystery to me why someone would pay several thousand € for a rocket ride but insist on using the cheapest computer available to them, based on checks notes a TV set-top box SoC that's not even rated for industrial thermal range, on a board that multiple high-speed design experts have on separate occasions and independently called "a surprisingly well-working piece of amateur art" in discussions with me. \$\endgroup\$ Feb 8, 2023 at 8:53
  • \$\begingroup\$ From the software/microcontroller point of view check out this thread on SO: Compiling an application for use in highly radioactive environments. \$\endgroup\$
    – Lundin
    Feb 8, 2023 at 8:57
    \$\begingroup\$ NASA is your friend. llis.nasa.gov/lesson/824 \$\endgroup\$ Feb 8, 2023 at 8:59
  • \$\begingroup\$ And to quote myself in the SO link above: "In general, use a MCU suitable for these kind of systems, and not some generic mainstream fluff you received in a packet of corn flakes." \$\endgroup\$
    – Lundin
    Feb 8, 2023 at 9:03
    \$\begingroup\$ Not an answer to your question, but you can get around any single event upsets with redundancy. SpaceX uses bog-standard X86 chips with triple redundancy, but their design is based around satellite redundancy as well by having thousands in orbit so having one suffering all three X86'es fail is accounted for, a luxury you don't have in a cubesat. What you probably need a number for is the risk of permanent latch up. \$\endgroup\$
    – winny
    Feb 8, 2023 at 9:26
You need to find out and write down your specs (what level of radiation are we looking at?, what are you trying to do?), temperature/cooling considerations (although temperature is not actually defined in space). Please research further for your specifications.
Additional edit: The amount of radiation exposure a satellite in low Earth orbit (LEO) experiences depends on several factors, such as the altitude of the orbit, the shielding of the satellite, and the current level of solar activity. Further research is needed and more information should be available to define the radiation that the electronics will have to handle.
An example of radiation based on altitude:
Effective dose rate depending on the altitude
Image Source: https://www.researchgate.net/publication/253302207_Space_Radiation_Measurement_on_the_Polar_Route_onboard_the_Korean_Commercial_Flights
If you would want to do a professional job using raspberry pi, you must look at each one of the raspberry's ICs to check what each can handle (based on your specs).
They all have their limitations and maximum radiation tolerances. Checking the datasheets of space graded ICs should solve your question. Space graded ICs have just different silicon inside.
I suggest using space graded ICs instead of trying to look for workarounds to that. You will avoid hassle and brain pain if you use proper ICs to do your job instead of looking at the errors later on from the watchdog.
----open source project(s)----
There are people making satellites already. If you follow a open source project like the below, you might see what ICs they are using and take some ideas: https://gitlab.com/librespacefoundation/upsat
----Videos----
Maybe this could help: EEVblog #896 - Space Electronics
And this: EEVblog #897 - Radiation Effects On Space Electronics
This video starting from 4:50 about space graded: EEVblog 1435 - The World's Most EXPENSIVE Catalog IC ?
  • \$\begingroup\$ Just to address the first part, "what level of radiation are we looking at" is what I'm wondering, as all I know is that we're going to LEO. I will deal with temperature issues separately, but I already have a good idea of what to expect and how to thoroughly validate that aspect. \$\endgroup\$
    – crossroad
    Feb 8, 2023 at 9:08
  • \$\begingroup\$ By the way, another issue that I barely mentioned in the question, is the fact that we are somewhat sensitive to cost. Vorago makes radiation hardened MCUs that I'd be very interested if not for their $1000 per piece price tag. I cannot justify spending that level of money without knowing closer to the exact odds that we're dealing with. \$\endgroup\$
    – crossroad
    Feb 8, 2023 at 9:18
    \$\begingroup\$ I suspect space grade IC's are a non starter for OP's project due to 1) cost and 2) availability/delivery times. A lot of providers of space grade IC's only build them as needed and so lead times can easily exceed 52 weeks. \$\endgroup\$
    – SteveSh
    Feb 8, 2023 at 13:49
    \$\begingroup\$ @SteveSh On top of that I think OP should research more. Its difficult to build a space graded electronics project while your questions are "how much radiation I will be facing?". Research is needed beforehand or a lot of money will get wasted. \$\endgroup\$ Feb 8, 2023 at 14:36
I'm going to take the first question.
The radiation environment in LEO is very well characterized and understood. Given the construction of your cubesat, the materials used, and the details of your orbit (for example, does it go through the SAA) you can come up with a fairly good estimate of what level of the various types of radiation your parts/design will see.
For more details on the LEO radiation environment, I would suggest you investigate the JPL or GSFC (Goddard Space Flight Center) websites.
