The following is the diagram of interest:
The impedance of the filter is:
$$Z_o=\frac{R_f L_f s}{R_f L_f C_f s^2+L_f s+R_f}$$
and the bode plot with all different components and the total impedance should look like this:
The way I intrupruted the frequency response is that the impedance follows the inductor at low frequency and it follows the capacitor at high frequencies and the resistor damps the resonance at the resonance frequency, which implies that the total impedance follows the resistor at the resonance frequency.
Now, what confuses me is that the instructor of the course I am taking said that this filter design is not good as it experiences resistor losses at low frequencies when the capacitor acts as an open circuit, which is also mention in Erickson and Maksimovic's book.
But as far as I can tell, at low frequencies the resistor will not introduce losses because the current will flow therough the inductor which looks like a short circuit at low frequency and this is exacly what the bode plot shows.
So, what does the instructor mean when he said the resistor will create losses at low frequency?
The instructor proposed the following alternative design to fix "the loss issue".
P.s. After giving the problem some though and more research I think what the instructor was referring to is the power dissipation from the input side. The parallel RC design acts as intended if we look at its impedance from the output side. however, if we look at it from the input side we will see that at low frequency, The impedance is purly DC and this is what the instructor meant by resistive power loss at DC.
if we derive the impedance and plot its Bode we get:
$$Z_{in}=\frac{R_fC_fL_fs^2+L_fs+R_f}{R_fC_fs+1}$$
On the other hand, the alternative design will have the additional series capacitance C_2 dominating at low frequencies, which prevents the resistance from disspiating DC power coming from the input side $$Z_{in}=\frac{R_fL_fC_{f1}C_{f2}s^3+(C_{f1}+C_{f2})s^2+R_fC_{f2}s+1}{R_fC_{f1}C_{f2}s^2+(C_{f1}+C_{f2})s}$$
Does my interpretation make sense? please let me know if you think otherwise.
