series/parallel circuit
I’ve been trying to figure out a way to solve this problem to no avail. I think it’s got to do with a voltage divider or voltage dropped. I’ve seen a number of questions on this topic but never one like this, where the value of particular resistor wasn’t given and has to be found, which also makes it difficult working out the total resistance in the circuit.
  • 4
    \$\begingroup\$ To get you started: if you know the voltage across R4, then you know the current through R4. This is the same as the current through R3, which means you can find the voltage across R3. \$\endgroup\$
    – vir
    Feb 13 at 20:41
  • 4
    \$\begingroup\$ If there's 5V across R4, how much current flows through R4? Now how much current flows through R3? So then what's the voltage across R3? So now you know the voltage across R3 & R4, so what's the voltage across R1? So if you then know the voltage across R1, what current flow through it? So this current "enters" the node at the top between R1, R2 & R3, and you've already calculated how much of that current goes down the R3 + R4 leg, how much goes down the R2 leg? So now you know the current through R2, and you already calculated the voltage across it earlier (it's in parallel with R3+R4), so ... \$\endgroup\$
    – brhans
    Feb 13 at 20:44
The question is asking you to apply both Kirchhoff's Voltage Law and Current Law, as well as Ohm's Law to solve.
We want to find R2. To do that we'll need to find its current, IR2 and voltage, VR2.
Besides the rest of the circuit values except for R2, they give you a key piece of information: voltage across R4 (VR4). Let's start with that.
  • Use Ohm's Law to find current IR4 = VR4/R4
  • Use Kirchhoff's Current Law to find current through R3 (IR3 = IR4, that is, recognize that they're the same)
  • Use Ohm's Law to find voltage VR3 = IR4*R3
  • Use Kirchhoff's Voltage Law to find VR2 = (VR3 + VR4).
With VR2 known, we move on to finding IR2:
  • Use Ohm's Law to calculate IR1 = (VR1/R1) = [(18V - VR2)/R1]
  • Use Kirchhoff's Current Law to calculate the net current through the R2 branch, as IR2 = (IR1 - IR4).
And finally:
  • Use Ohm's Law to calculate R2 = (IR2 / VR2).
Quick review of Kirchhoff's Laws:
  • Voltage Law: Directed sum of all voltages around a closed loop is zero
(Battery [18V] is a positive value, while all the IR drops in the resistors are negative. All add up to zero.)
  • Current Law: Sum of all currents flowing into and out of one node is zero
(Current through R1 into R2/R3/R4 node branches into currents out via R2 and R3+R4.)
  • \$\begingroup\$ Wonderful analysis and explaination, this has been bothering me for hours but you just made it look too easy Thanks pal \$\endgroup\$
    – Tasha
    Feb 14 at 13:15
The others have said it, but I'll list it out here in order of how I would solve it:
  1. Perform nodal voltage analysis - There will be two unknowns, one of them being R2, the other being V(R2).
  2. The voltage they gave you is important, use V = I*R to solve for I4. Because R3 and R4 are in series, the current is the same.
  3. You now know I4 = I3, therefore you also now know V(R3). Why is that helpful? Well, the voltage across V(R2) is in parallel with V(R3) + V(R4), otherwise, V(R2) = V(R3) + V(R4)
  4. Going back to the original voltage nodal equation you did in step 1, now, there is only 1 unknown, the resistance value of R2.
Try and go through the process and do the numbers, and post what you get; otherwise, comment if you get stuck.
Cheers.
  • \$\begingroup\$ Thanks pal your analysis is similar to that of the others, it makes so much sense now \$\endgroup\$
    – Tasha
    Feb 14 at 13:19
  • \$\begingroup\$ No problem! glad it helped \$\endgroup\$ Feb 14 at 15:59
