I have a Python program for reading both TDS and pH sensors on a Raspberry Pi 4 and sending the data to the Blynk app.
I have a question about the code:
import RPi.GPIO as GPIO
import board
import busio
import time
import sys
import adafruit_ads1x15.ads1115 as ADS
from adafruit_ads1x15.analog_in import AnalogIn
import requests
GPIO.setmode(GPIO.BCM)
GPIO.setup(20, GPIO.OUT)
GPIO.setup(21, GPIO.OUT)
GPIO.output(20, GPIO.HIGH)
GPIO.output(21, GPIO.HIGH)
token="##"
# Setup
i2c = busio.I2C(board.SCL, board.SDA)
ads = ADS.ADS1115(i2c)
def ph_sensor():
pH = 20
GPIO.setup(pH, GPIO.OUT)
GPIO.output(pH, GPIO.LOW)
channel = AnalogIn(ads, ADS.P0)
buf = list()
for i in range(20): # Take 10 samples
buf.append(channel.voltage)
buf.sort() # Sort samples and discard highest and lowest
buf = buf[4:-4]
avg = (sum(map(float,buf))/12) # Get average value from remaining 6
ph = round(avg/0.34286,2)
time.sleep(10)
GPIO.output(pH, GPIO.HIGH)
return ph
def ppm():
TDS = 21
GPIO.setup(TDS, GPIO.OUT)
GPIO.output(TDS, GPIO.LOW)
channel = AnalogIn(ads, ADS.P1)
buf = list()
buf.append(channel.voltage)#-0.373212)
buf = buf[4:-4]
avg = (sum(map(float,buf))/6) # Get average value from remaining 6
ppm = abs(round(((avg*1000)/2.3),2))
time.sleep(10)
GPIO.output(TDS, GPIO.HIGH)
return ppm
def write(token,pin,value):
api_url = "https://blynk.cloud/external/api/update?token="+token+"&"+pin+"="+value
response = requests.get(api_url)
write(token,"v2",str(ppm()))
time.sleep(5)
write(token,"v3",str(ph_sensor()))
- In this line of code
, why do we divide by 0.34286? What does this number even mean? - In this line of code
why do we multiply by 1000 and then divide by 2.3? Can anyone explain?
