I'm trying to find the datasheet and/or documentation of the flash memory chips on this SSD drive board. The chip is marked 29F32B2ALCMG2, and though my web searches did not come up with any sources, I did find many Chinese forums discussing the chip.
I have some hints the chip might have been made by Intel, but I'm not sure. Any suggestions?
Layout of the board
It's an Intel NAND flash chip. You can find it under the article number "PF29F32B2ALCMG2S LMBA" on Mouser (there is no stock though). Finding a data sheet for this particular chip is difficult, because Intel doesn't seem to make them available to the public. I could find a datasheet for a similar chip that may give some hints about this one:
Intel NAND info
With this information PF29F32B2ALCMG2S seems to mean:
PF -> BGA package
29F -> NAND Flash memory
32B -> 256 Gbits
2A -> Probably device bus identifier
L -> 1 Die, 1 CE, 1 R/B
C -> 3.3V
M -> MLC NAND Flash Memory
G2 -> Probably litography code
S -> Client SKU
Maybe someone else will find the exact datasheet.
