I want to get started with ATWINC-IC from Microchip. It's a WiFi IC that I'm going to implement onto a PCB.
I have installed Microchip Studio and now I'm looking for how to start a project with that IC. I assume that with ATWINC-IC, I can program the IC with I2C or UART.
So to begin with, I need to know which programmer I should use for this ATWINC-IC and what software I should use and how do I create a first time hello world project to deploy onto that WiFi-chip e.g a web page or blink an LED.
https://www.microchip.com/en-us/product/ATWINC1500-IC
The ATWINC1500 is a network controller; it does not function standalone, and must be driven by another microcontroller using the SPI interface (clock, chip select, data in, data out), and a few other lines (wake, enable, reset and interrupt).
The device is pre-programmed, so you don't initially need a programmer; you'll be writing code for the microcontroller that is driving the device. Here is an example using RP2040 with ATWINC1500
  • \$\begingroup\$ I understand! Sounds nice to hear that this WiFi controller is pre-programmed and does not require any more programming. All I need to do is to have SPI connection to a host MCU. Thank you. Thinks information was very helpful. \$\endgroup\$
    – euraad
    Feb 19 at 15:21
  • \$\begingroup\$ One question more. The ATWINC1500-IC...is that pre-programmed as well? The naked IC-chip. \$\endgroup\$
    – euraad
    Feb 19 at 15:38
  • \$\begingroup\$ I don't know, you'll have to ask on the Microchip forum, but if you are a newcomer to this device, I'd strongly suggest starting with a module, to avoid tricky microwave design. \$\endgroup\$
    – jayben
    Feb 19 at 22:32
  • \$\begingroup\$ Thank you. I will use WF200 instead. Seems to be suitable for STM32. \$\endgroup\$
    – euraad
    Feb 19 at 22:42
The link you posted has a long list of documentation including a programming guide, I would start there.
