I am trying to simulate the CMOS inverter (on the Tanner EDA S-edit tool). I am getting an error as follows -
Error: Simulation file "C:\Users\Carl\AppData\Local\Temp\inv_layout_tb.tsim" does not exist
Fatal Error: "inv_layout_tb.sp" line 24
Library File "C:\Users\TannerEDA\TannerTools_v2019.2\Process\Generic_250nm\Models\Generic_250nm. lib" not found!
and the error seems to be in this line - lib C:\Users\TannerEDA\TannerTools_v2019.2\Process\Generic_250nm\Models\Generic_250nm.lib" TT
And I wanted to design the layout for this, I am using L-Edit for that.
When I tried Creating a new Design in L-Edit, it crashes showing an error that goes away as soon as I click on "OK"
Does anyone know, how to solve this problem?
P.S: I am using Windows 11, and S-edit and L-edit version 2019.2
The test bench for the above CMOS Inverter is as follows - enter image description here
  • \$\begingroup\$ I am also facing the same error. Have you found the answer? I am also using the same version as you. "C:\Users\Carl\AppData\Local\Temp\inv_layout_tb.tsim" does not exist \$\endgroup\$ Oct 19, 2023 at 20:42
Sounds like it cannot find your model file. Have you checked that it's actually located in that location set "C:\Users\TannerEDA\TannerTools_v2019.2\Process\Generic_250nm\Models\Generic_250nm.lib"
  • \$\begingroup\$ Yes, I did check. It is located in that location nset \$\endgroup\$
    – Achyuth SS
    Feb 20, 2023 at 2:17
