I want my program to flash compile time error like "LCD_PORT not defined" if it is not defined in program itself. For that I modified the header file like this
#if LCD_IO_MODE
#ifndef LCD_PORT
#error LCD_PORT not defined //(e.g. #define LCD_PORT PORTA/B/C/D)
#endif
#define LCD_DATA0_PORT   LCD_PORT     /**< port for 4bit data bit 0 */
#define LCD_DATA1_PORT   LCD_PORT     /**< port for 4bit data bit 1 */
But even after defining the LCD_PORT (like in the following program), it flashes the error.
#include <avr/io.h>
#include <lcd.h>
int main(void)
    lcd_init(LCD_DISP_ON_CURSOR);
    lcd_home();
    lcd_gotoxy(0,4);
    lcd_puts("Hello world!!");
  • \$\begingroup\$ Modifying distribution header files is bad practice. Why not move these lines into your own source code? \$\endgroup\$
    – jippie
    Apr 13, 2013 at 8:12
The problem is likely to be that the preprocessor operates sequentially so you should perform the define before the include. Try the following:
#include <avr/io.h>
#include <lcd.h>
    \$\begingroup\$ Exactly. The included header is processed before the #define is reached. \$\endgroup\$
    – Passerby
    Apr 13, 2013 at 8:31
