I am trying to make a simple class A audio amplifier with one transistor (TIP41, NPN) in common emitter configuration as shown in the pictures.
circuit when idle/ no input signal
The problem I have is that when I add the input signal (more than 1 V), the transistor's base bias changes quickly from positive to negative in such a way that no usable amplification is possible. I can get 1 V/0.2 A output at best from the 10 V/0.57 A supply input. That's 3.5% efficiency.
circuit under 1V audio input signal
Should the input signal stay under 1 V, is that the cause of bias change? Is the signal too strong for this base bias current? If so, how are signals amplified further (in large amplifiers,) if the final stages can't take more than 1 V or close? It can't be right.
  • 4
    \$\begingroup\$ Well, larger amplifiers aren't typically single-transistor class-A designs, so the question "how are in large amplifiers signals amplified further" might be answered with "by using a different design that doesn't have as bad an efficiency". Also, this would seem to be like a mid-60s design: humongously strong base bias resistors, no feedback whatsoever, a transistor with a hFE < 100 … \$\endgroup\$ Feb 22, 2023 at 17:55
    \$\begingroup\$ What is the purpose of the emitter resistor in a common emitter amplifier. \$\endgroup\$
    Feb 22, 2023 at 18:27
  • \$\begingroup\$ @Marcus Müller Yes, the design and approach matters, I meant something probably unfeasible (how large signals are made/ amplified - NOT by cramming them into base-emitter circuits, I understand now) My montage is the classic one, from the books (so it is old, indeed), I want to see it working. \$\endgroup\$ Feb 22, 2023 at 19:02
  • \$\begingroup\$ @Andy aka As I already said to ErnestoG, I will try this approach, thank you for the link. \$\endgroup\$ Feb 22, 2023 at 19:02
  • \$\begingroup\$ You need an oscilloscope. When you drive the input with large signals, output is distorted, and transistor operation has exited "Class A" - it is no longer a linear amplifier. An oscilloscope will reveal that output wave shape is not an inverted version of input wave shape. \$\endgroup\$
    – glen_geek
    Feb 22, 2023 at 19:03
5 Answers 5
Have a look at the behaviour of this transistor, as its base voltage is changed. Here's the circuit with just the transistor and a collector resistor:
This is what happens to the collector C potential, as the base B is swept from 0 to +1V (with respect to the emitter):
As you can see, the collector potential cannot ever rise above the positive supply of +10V, or below the emitter at 0V. This means that the only useful region of operation (from an audio perspective - digital is a different story) is in the part of this graph between the green markers.
Base potential must remain at all times between 0.67V and 0.75V, if you wish to avoid "clamping" the collector against either supply potential.
That's a range of less than 0.1V, so if you apply a signal with amplitude 1V, the base will spend most of its time well outside those limits, and the output will clamped to either +10V or 0V most of the time.
This common-emitter design is suitable only for very small amplitude inputs, significantly smaller than 0.1V.
Now let's address your biasing of the base, with resistors 690Ω and 620Ω. These form a potential divider, which will attempt to provide a potential about half way between the supplies, at the transistor's base. That's only an estimate, based on the similarity of their values, a simulation will show us the real value, on the left voltmeter:
That's already far above the 0.7V-ish point where you need the transistor's base to be "centered" around.
On the right is what happens to that potential with the transistor in place. The base and emitter of the transistor behave as if there was a diode between them (because, technically there is one), and this diode to "ground" prevents the base from rising much higher than 0.7V. Here the voltmeter shows 0.88V, which again is way outside the range of potentials you need to be providing at the base.
The transistor is clearly driven so hard into conduction, that its collector is super-glued to 0V. To get it out of this state would required a very strong input, able to pull very hard, downwards, the potential of the node at the resistors' junction and transistor base.
While what I am about to suggest is by no means a "good" solution, it might at least help you get somewhere with your experimentation. I suggest you change your resistances to try and achieve +0.7V at the base:
Have a play with the simulation, to see what voltages appear in various places as you change the resistances. Pay close attention to collector voltage too.
There are other issues, but these two must be fixed before I could begin to talk about the others. I hope you've got a better grasp why your circuit cannot hope to operate as an audio amplifier, in its current configuration.
    \$\begingroup\$ Thank you very much for the efforts to explain to me the phenomenon - you gave me the best clarification posible. I am now able to fully understand the problems brought by voltage input. I will simulate on my own those three configurations possible for the transistors, to find what suits me best, and after that I will make probably a few complementary stages out of them. The topic can be closed I think, since the problem is solved for me. Thank you again to everyone. (edit: the other issues with the circuit will not be a problem anymore, now that I got the main mistake) \$\endgroup\$ Feb 23, 2023 at 15:11
This is happening because you're not using negative feedback.
For a common-emitter amplifier like this you need series-series feedback (AKA emitter degeneration). This will desensitize your transfer from beta (current gain) variations.
If you really need the gain, then you can also include a parallel capacitor with such resistor so that the emitter is grounded at AC (you still get the negative feedback at DC, so your transistor will be biased properly). However, this will make your AC transfer more sensitive to beta variations, so you'll suffer from more distortion.
Whatever you choose, you need feedback for linear amplification, there no other way.
If you must use stages like these for amplification, you can ditch the divider and make an inverting amplifier; connect the output to the 1st stage base node, and place another resistor in series so that you can define your gain as the classical inverting amplifier. This way you make good use of the large open-loop gain these common-emitter stages provide.
EDIT:
Perhaps I read your question too quick. If you're trying to have a predictable voltage gain and able to feed 3A into a load, there is no way you can do this with a single stage, much less with a textbook common-emitter amplifier.
The fundamental problem with a common-emitter amplifier is that, it's basically a transconductance amplifier with a predictable load (the collector resistor), i.e. it needs a predictable load for a predictable linear gain (and the quiescent collector current is fixed by the emitter voltage divided by the emitter resistor you added). You say you want to feed to a 4 ohm load that will be, effectively, in parallel with your collector resistor. Your gain will vary, and the current you have fixed with the series-series feedback (the emitter resistor) will now have to be shared among your load and collector resistor.
The only decent use for a common-emitter is as a preamplifier (or if your load is >2 orders of magnitude higher than your collector resistance), while subsequent buffer can provide the current capability you use.
I see you have agreed that you should change your approach for this design. Good luck!
  • \$\begingroup\$ I will try to add this feedback resistor to the circuit. I knew about it, but I thought it is for overheat protection mainly. Maybe if I make the base to be at some positive potential through emitter resistance, the the bias will not drop anymore? - I will check this out. For start, I want to have a working model of one single transistor - you can tell why. In the specifications, this transistor handles up to 100 V/ 6 A / 65 Watts total. I wish to see that with my eyes - an output even of 12 V/ 3 A would be huge for me. \$\endgroup\$ Feb 22, 2023 at 19:02
  • \$\begingroup\$ @AlinPaladin are you saying that your load is 4 ohms? (12V/3A) \$\endgroup\$
    – Designalog
    Feb 22, 2023 at 19:41
  • \$\begingroup\$ @AlinPaladin The 65 W is an absolute maximum. Same with 6 A. Same with 100 V. Note also that the 65 W only works if and only if you can somehow guarantee that the case stays at 25 C and that the chip die itself doesn't experience anything anywhere on it that goes over 150 C. The safe operating area spec points out the obvious: if the VCE > 10 V then the max current goes down and at 100 V can only be 200 mA. Note also that while (150 C - 25 C)/65 W suggests junction to ambient of >1.9, it is really a little better at about 1.7. But they are being safe, just in case. \$\endgroup\$ Feb 22, 2023 at 20:06
  • \$\begingroup\$ @AlinPaladin Using a heat sink like this doesn't even specify it's dissipation in still air. But with a little bit of flow they give about 10 C/W. Then there's the thermal compound -- maybe another 0.5 C/W at a guess with a thin layer using 'good stuff'? So this is perhaps 10+0.5+1.7 or about 12 C/W from the die to air using that heat sink and a small breeze. Using a risky 100 C rise, which I would not do, and a fancy heat sink you might get about 8 watts out of it. Being conservative, half that much. \$\endgroup\$ Feb 22, 2023 at 20:36
  • \$\begingroup\$ @AlinPaladin And that assumes your ambient is 25 C. Since it might operate in 55 C environs, you can use a risky (125 C - 55 C)/12 = 5.8 W or a less risky (85 C - 55 C)/12 = 2.5 W. The point of all this is to disabuse you of the idea that 65 W is practical. It's what the device might do if you could find a way keep ambient at 25 C (55 C isn't possible) and could find a thermal solution that adds no more than 0.22 W/C to the thermal resistance. Good luck with that! \$\endgroup\$ Feb 22, 2023 at 20:55
This phenomenon is not so much related to transistor amplifier circuits but rather to diode rectifier circuits. There it has been known and used for a long time (especially in TV receivers) in the so-called "DC restoration circuits". Here is my explanation.
Equivalent circuit
With a large input signal, the base-emitter junction can be considered as a diode; so the input part of the circuit can be simplified to the following form.
Simplified equivalent circuit
To see the basic idea clearly, we can simplify the circuit even more by removing the resistors and replacing the diode with an "ideal" one (VF = 0 V). Thus we obtain the following conceptual schematic.
During the positive half-wave, the diode is "on" and the capacitor quickly charges through it; during the negative half-wave, the diode is "off" and the capacitor has nowhere to discharge.
As a result, the capacitor remains permanently charged to a voltage equal to the peak of the input voltage. This DC voltage is subtracted from the input AC voltage and drops it below zero.
Graph_1 Extremely simplified equivalent circuit
In fact, the diode is permanently "off". So we can remove it from the circuit diagram and replace the charged capacitor with a constant voltage source with the same voltage Voff = Vc. Thus we get an extremely simple conceptual circuit diagram.
Graph_2
If we compare the two graphs, we see that they are the same except for the initial part where the capacitor must be charged.
    \$\begingroup\$ Thank you for your explanations. I have already got the reason why I can't go over some 0.1 V input, for the current common emitter configuration, from Simon Fitch, posted above. I know now where I was making mistakes - wrong transistor configuration for the input signal - that's why it didn't amplify a thing. I am pretty set now, with the explanations I got, and with the aid of the simulation software, I will search for the right transistor configurations for my particular requirements. The topic can be closed, and marked as solved. \$\endgroup\$ Feb 23, 2023 at 15:25
  • \$\begingroup\$ Doesn't the first model place the output at the emitter, but it's really on the collector? \$\endgroup\$ Feb 23, 2023 at 20:41
    \$\begingroup\$ @Scott Seidman, I have considered the circuit of C, R1 and R2 as a bias (or DC restoration) circuit with its own input and output. I was hesitant to label it with BASE instead of OUT but I wanted it to be more symmetrical. Do you approve of my idea to present the input part of the circuit as a DC restoration circuit? It emerged in my mind from a very distant time (the 80s) when I was studying with interest the complex analog and pulse circuits of TV receivers. I think there were such detectors that used the base-emitter transition of the transistor as a diode... \$\endgroup\$ Feb 23, 2023 at 21:09
    \$\begingroup\$ I missed the phrase "input side" in your post. With that, I think the post is OK, but would be clearer if you labeled the point V sub b, to match the original poster's notation. He uses "out" differently. \$\endgroup\$ Feb 24, 2023 at 1:09
Your transistor has way too much base current causing its bottom of the output waveform to be clipping. Since it is class-A without any negative feedback then it is normal for the top of its output waveform to be squashed.
I do not has a model for a TIP41 so I used a similar transistor. There is a high range of the hFE of a transistor part number anyway that needs selection or DC negative feedback to be used.
The distortion sounds awful and the heating is absurd for the small amount of output power. It will have much more trouble trying to drive a speaker. class-A
  • \$\begingroup\$ The circuit looks correct (it is like what I have), and I am sure the different model used doesn't change things that much, yet I say I had 1 V input without audible distorsions (before modifications). Now, with some resistances added to the emitter, audio works fine up to 3 V! input (but the power output is the same - 0.2-0.4 W). Signal used is 50 hz, multimeter shows 3 V at the input point. Unfortunately I don't have something better than a regular multimeter, that's why I do measurements at 50 Hz, it is it's expected working frequency. \$\endgroup\$ Feb 22, 2023 at 22:04
  • \$\begingroup\$ A multimeter cannot measure distortion. Since the amplifier distortion is so high then the multimeter also cannot correctly read the output volts and amps. At 50Hz the output capacitor is 32 ohms. Most multimeters read volts RMS which is 0.707 times the peak voltages in my simulations that show about 60% distortion when the input is only 40mV peak which is 28.3mV RMS (0.0283V RMS). I forgot to say that the input resistance of your amplifier is VERY low, about 30 ohms. \$\endgroup\$
    – Audioguru
    Feb 22, 2023 at 22:59
  • \$\begingroup\$ My multimeter is a cheap one, which gives orientative readings. Of course I can't measure distortion with it, but what preoccupies me the most is the lack of power. Even with the approximate readings, for 15 watts in, I get 0.2 watts out, no distorsions. For 80 watts in, I get 1.5 watts out, no distorsions heard - sound is good. I say there's a problem either with the montage, either with my expectations about how much amplification a transistor can give. \$\endgroup\$ Feb 23, 2023 at 0:13
  • \$\begingroup\$ Your problems are caused by using cheap and antique class-A. \$\endgroup\$
    – Audioguru
    Feb 23, 2023 at 1:18
  • \$\begingroup\$ @ Audioguru I agree that this kind of montage is obsolete, yet I wish to see it working, as it is depicted in the specifications. That is the main point - it is said that one transistor can handle a current up to 100 times the input, for example. I want to have a working model of that, with as few components as they are in the diagrams. The type I am using is said to modulate 6 A/ 65 W. Well .. I want to see those numbers, one way or another. I can't take "max 0.3 A, 2 W" as an answer. \$\endgroup\$ Feb 23, 2023 at 1:41
The input \$1000\mu F\$ capacitor (I suspect is polarized) is correctly biased when the input is 1V. When 0V is applied the capacitor is essentially a short.
The input voltage must be less than 500 mV.
Edit: This also explains why an emitter resistor allows a higher input voltage.
  • \$\begingroup\$ Capacitor is there only to stop DC going from one circuit to another. I have tried to reduce the input voltage (by using resistors), but this doesn't make the transistor operate any better - from the output of 0.2 watts at 10 V, it drops to insignificant amounts. The transistor is rated to 65 watts, I expect more than what currently does - I gave it 30 V, 2.5 A ,it has outputted 2 watts clean sound - obviously something is wrong, that's not amplification by any means. Even the input source does more than that, with way less power. \$\endgroup\$ Feb 23, 2023 at 0:24
    – Audioguru
    Feb 23, 2023 at 1:17
    \$\begingroup\$ Electrolytic capacitors block dc in one direction only @AlinPaladin \$\endgroup\$
    – RussellH
    Feb 23, 2023 at 1:58
  • \$\begingroup\$ @RussellH What is that direction please? I was expecting to have it blocked in any direction? The collector bias gets blocked like this - until I have added the decoupling on the output, the current bias flowed into the speaker, now it doesn't. Also, speaking about, I have tried an old software (Electronics Workbench) and it seems that there are indeed some problems with both capacitor value and input signal value (no more than a few hundred mV), I will work more on that. In practice it didn't appear so, I have to check it more thoroughly now. \$\endgroup\$ Feb 23, 2023 at 2:26
    \$\begingroup\$ @AlinPaladin You really should draw the "+" symbol on the schematic, in agreement with the polarization of the capacitor in your circuit! The capacitor behaves like a capacitor when the "+" terminal is higher than the "-" terminal. When the voltage across the polarized electrolytic capacitor is reversed, it will act as something else, but definitely not a capacitor anymore. \$\endgroup\$ Feb 23, 2023 at 2:38
