The counter only last for one clock cycle but I want the test_counter remain unchanged until next button_case.
test_counter should transition like this "0000" -> "0010" -> "0001" ->"0100" -> "1000" -> "0000"
I have tried this below but it's not working.
when others      => null; -- do nothing
when others => knapp_in_1_n <= knapp_in_1_n; gives me the following wave.
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity testbench_keypad_v2 is
end entity;
-- testbench for keypad scan
architecture rtl OF testbench_keypad_v2 is
-- constants
constant sys_clk_period : TIME := 100 ns;
-- signals
signal sys_clk           : std_logic;
signal led               : std_logic_vector(3 downto 0);
signal knapp_in_1_n      : std_logic_vector(3 downto 0) := b"0000";
signal reset_n           : std_logic;
constant default_value   : unsigned(25 downto 0) := 26d"200000";   -- 20ms
signal  test_counter     : unsigned(25 downto 0) := 26d"0";
signal prev_test_counter : unsigned(25 downto 0) := (others => '0');
component keypad_v1
port (
    clk, reset_n         : in  std_logic;
    key_in               : in  std_logic_vector(3 downto 0);
    key_out              : out std_logic_vector(3 downto 0);
    led_display          : out std_logic_vector(3 downto 0)
end component;
begin
    i1 : keypad_v1
    PORT MAP (
        -- list connections between master ports and signals
        clk                => sys_clk,
        led_display        => led,
        key_in             => knapp_in_1_n,
        reset_n            => reset_n
    clock: process
    begin
        -- Clock period
        sys_clk <= '0';
        wait for sys_clk_period/2;
        sys_clk <= '1';
         -- Här upprepas processen, ”GO TO Start”
    end process;
    reset: process
    begin
         -- Reset at start up
        reset_n <= '0';
        wait for 5*sys_clk_period;
        -- Target running
        reset_n <= '1';
        wait; -- test case 5
        -- ett tomt “WAIT;” stannar processen, eftersom det finns inget villkor
    end process;
    counter_cases : process(sys_clk)
    begin
        if rising_edge(sys_clk) then
            if test_counter < default_value then
                test_counter <= test_counter + 1;
            else
                test_counter <= (others => '0') after 150 ns; -- 150 ns is 1.5 sys_clk
            end if;
        end if;
    end process;
    button_case: process(test_counter)
    begin
        case test_counter is
            when 26d"100001" => knapp_in_1_n <= "0001";
            when 26d"266668" => knapp_in_1_n <= "0010";
            when 26d"800014" => knapp_in_1_n <= "1000";
            when 26d"600015" => knapp_in_1_n <= "0100";
            when others      => knapp_in_1_n <= "0000"; -- do nothing
      end case;
    end process;
end rtl;
If you don't want your test_counter to reset, then you shouldn't do it
else
But do be honest, I'm not really sure what you want to achieve. It seems you want button_case to depend on test_counter and vice-versa.
Update:
If you want knapp_in_1_n to keep its value after a case assignment, change the others statement to
But you then need an additional condition/case to set knapp_in_1_n back to "0000" but only you know when this is.
  • \$\begingroup\$ I want it to keep its value until next transition. test_counter should transition like this "0000" -> "0010" -> "0001" ->"0100" -> "1000" -> "0000" \$\endgroup\$
    – kile
    Commented Feb 27, 2023 at 8:19
  • \$\begingroup\$ you mean knapp_in_1_n should transition like this? I updated the answer \$\endgroup\$
    – po.pe
    Commented Feb 27, 2023 at 8:53
  • \$\begingroup\$ It doesn't work even with when others => knapp_in_1_n <= knapp_in_1_n; See my updated question \$\endgroup\$
    – kile
    Commented Feb 27, 2023 at 13:59
  • \$\begingroup\$ What exactly is the problem with the new sequence? knapp_in_1_n now seems to be stable after change... \$\endgroup\$
    – po.pe
    Commented Feb 27, 2023 at 14:17
  • \$\begingroup\$ knapp_in_1_n should change to knapp_in_1_n <= "0100" when test_counter reaches 26d"600015" However, It doesn't change in the wave form \$\endgroup\$
    – kile
    Commented Feb 27, 2023 at 19:58
