I am writing code that behaves as a rudimentary register file. I have created the register file as a module reg_file.v. The code instantiates a module, describing a register with loading capabilities, using generate with a simple 'for' loop.
When trying to implement the register module, I get the forementioned error. Here is the register module:
`timescale 1ns / 1ps
module simple_register_load
#(parameter N = 4)(
input clk,
input load,
input [N - 1:0] I,
output [N - 1:0] Q
reg [N - 1:0] Q_reg, Q_next;
always @(posedge clk)
begin
Q_reg <= Q_next;
end
// Next State logic
always @(load, I, Q_reg)
begin
if (load)
Q_next = I;
else
Q_next = Q_reg;
end
// Output logic
assign Q = Q_reg;
endmodule
Within the "Next State Logic" the line associated with Q_reg <= Q_next gets flagged for the error.
begin
Q_reg <= Q_next;
end
I have searched the forums and have found others with similar issues, and they all point to modifying an output in multiple 'always' statements. But here, I only modify Q_reg in one of the 'always' blocks. Q_next is also only modified in one 'always' block. I am puzzled.
This is the register file module code for reference:
module reg_file
#(parameter N = 4, BITS = 4)(
input clk,
input [N - 1:0] address_w, address_r, //write address, read address
input WE, //write enable
input [BITS - 1:0] data_w, // write data
output [BITS - 1:0] data_r // read data
input read_write_sel
wire [2**N - 1:0] address_w_dec, address_r_dec;
wire [BITS - 1:0] reg_data;
// WRITE PORT
decoder_generic #(.N(N)) write_decoder( // N x 2^N decoder
.w(address_w),
.en(WE),
.y(address_w_dec)
// READ PORT
decoder_generic #(.N(N)) read_decoder( // N x 2^N decoder
.w(address_r),
.en(~WE),
.y(address_r_dec)
// REGISTERS
genvar k;
generate
for(k = 0; k < 2**N; k = k + 1)
begin: register
simple_register_load #(.N(BITS)) R(
.clk(clk),
.load(address_w_dec[k]),
.I(data_w),
.Q(reg_data)
assign data_r = address_r_dec[k] ? reg_data : 'bz;
end
endgenerate
endmodule
The errors if I run for N = 1 (generate 2^N = 2 registers):
[DRC MDRV-1] Multiple Driver Nets: Net nolabel_line34/register[1].R/Q[1] has multiple drivers: nolabel_line34/register[0].R/Q_reg_reg[1]/Q, and nolabel_line34/register[1].R/Q_reg_reg[1]/Q.
[DRC MDRV-1] Multiple Driver Nets: Net nolabel_line34/register[1].R/Q[2] has multiple drivers: nolabel_line34/register[0].R/Q_reg_reg[2]/Q, and nolabel_line34/register[1].R/Q_reg_reg[2]/Q.
[DRC MDRV-1] Multiple Driver Nets: Net nolabel_line34/register[1].R/Q[3] has multiple drivers: nolabel_line34/register[0].R/Q_reg_reg[3]/Q, and nolabel_line34/register[1].R/Q_reg_reg[3]/Q.
I feel like there is a really simple issue that I am missing, and I would be very grateful if someone could point it out.
reg_data
. This needs to be a separate bus for each instance of a register. \$\endgroup\$reg_data
inside the generate loop. See here for an example. \$\endgroup\$
