I am testing a LEM LTSR-25-NP current transducer. According to the datasheet, the current transducer should be outputting 2.5 V +/- 0.025 V when the input current is 0 A, but this is not what I am experiencing.
It seems that every time I set up the current transducer using a breadboard, jumper cables, an STM32 MCU, and thd necessary power supplies, I get a different output voltage at 0 A. I got output voltage ranging from 2.6 V all the way up to 3.2 V.
I have also noticed that by moving the jumper cables that are near the transducer, the output voltage changes.
Yesterday I decided to ground the reference pin for a second and see what happens and it actually managed to fix the issue; the output was exactly 2.5 V, but today I tried it again and it doesn't work.
Does anybody have an idea of what may be going on here?
