I have a board that is failing radiated EMC tests. There are narrowband spikes with 50 MHz intervals (300 MHz, 350 MHz, 400 MHz, etc.)
I believe it has something to do with a clock (I suspect so since 50 MHz seems to be the "base frequency" and that is a very even number).
EMC chamber time is very expensive so I thought I would look for the problem with near-field probes. I have access to a spectrum analyzer, but I haven't used these probes much before.
So what is the logical choice when one is looking for this 50 MHz clock (might be some internal clock on some chip since I have no such crystal on the board), H-field or E-field probes?
What are the two types of probes usually used for? Some example? Is one for current and the other for voltage?
As clock signals are generally low current and high impedance sources in nature, an E-field probe would be the first choice for measurements in the near-field. Oscillators and clock signals are actually the classic example for E-field emissions.
H-field probes are usually used for low impedance and high current sources, e. g. things related to power distribution.
Fundamentally, E-field probes respond to voltage changes and H-field probes respond to current changes.
Having said that, I would still recommend to have both types at hand. You can buy near-field probe sets that usually have an E-field probe and a set of H-field probes (different sizes). Those sets are not very expensive these days.
  • \$\begingroup\$ OK, great answer. Thank you! \$\endgroup\$
    – aaq
    Mar 2 at 7:52
