I'm using the onboard software watchdog facility of an Atmega328 like documented here.
My purpose is to limit to 2 seconds the execution of a portion of code that could lead to endless computation.
This is the pseudo-code scheme:
enable watchdog (2 seconds)
run may-be-endless code
clear watchdog
run the rest
The rest of the code should be run if the may-be-endless code manage to run in the given amount of time, otherwise the whole program must be restarted.
This is the Arduino code I loaded into the board:
#include <avr/wdt.h>
void setup() {
Serial.begin(9600);
Serial.println("Started");
wdt_enable(WDTO_2S);
Serial.println("watchdog ON");
wdt_reset();
Serial.println("watchdog OFF");
void loop(){
Serial.println("loop...");
delay(1000);
At this point, the expected output should be an endless printing of loop...
messages, after the ones in the setup (Started
, watchdog ON
/OFF
Surprisingly, what I get instead is this:
Started
watchdog ON
watchdog OFF
loop...
loop...
loop...
Started
watchdog ON
watchdog OFF
loop...
loop...
loop...
Started
watchdog ON
watchdog OFF
loop...
loop...
Appartently the watchdog is being set but can't be cleared. How come?
